Results 1 to 7 of 7
Thread: Help with light load bucking/jerking.
    Dec 2018
    25
    I have a bucking/jerking issue at light throttle, low load cruise conditions (almost as if the car thinks I'm making throttle transitions.)
    Initially thought it was A/F ratio related, but looks like it might be timing... not sure.
    The graph for my timing looks like a saw blade when it's doing it, so that's why I'm leaning that way. (Not sure if fluctuating timing is CAUSING the issue or adjusting in an attempt to compensate.)
    Not sure why timing is changing in a steady-state cruise like that.
    Hopefully you guys know where I need to look, or if there's another parameter I should be logging.
    2001 Corvette
    Manual Trans
    LS3 Swapped
    BTR Supercharger Cam (medium size)
    Vortech T-Trim
    LS9 Map Sensor
    3 Bar SD OS conversion
    Long Tube Headers (with factory O2 sensors and a wideband in bank 1)
    80lb injectors
    Jun 2007
    Finland, Europe
    550
    Start with tuning Base Running Airflow (under Idle/Airflow). Log desired idle airfllow, as well as LTIT and STIT.
    Jun 2007
    Finland, Europe
    550
    Oh, and your max rotation with ETC seems to be fine now..
    Dec 2018
    25
    Quote Originally Posted by Pekka_Perkeles View Post
    Can you give me a quick explanation on how to do that? Are LTIT and STIT long term idle trim and short term idle trim?
    Nevermind, I just watched a video explaining it.
    Dec 2018
    25
    I'm still getting an occasional P1515 or P1516 from time to time. Either when I hit the rev limiter or when I'm at very low MAP and low RPM (foot off the gas, coasting down a steep hill, in high gear).
    These aren't super pressing issues right now because I know how to keep from getting it into those conditions. (I set the rev limiter higher than I need to shift at.)
    It IS super frustrating when it does go REP though because it goes super lean and messes up any of my data-logging that I'm currently working on.
    Thanks for all your help so far!
    Dec 2018
    25
    So just an update on this...
    I found a solution in a reply to a different thread. Long story short, the difference between my Idle Spark Advance table and my Main Spark Advance table (in the cruising ranges) was too dramatic. The car was transitioning between the two tables and timing was jumping. I had no idea it was still using the "Idle" table at that RPM range.
    I just copied my Main Spark Advance table and pasted it into the Idle Spark Advance table, and it alleviated my jerking/bucking issue SIGNIFICANTLY!
    It will still buck once or twice transitioning from off to on throttle, but they are minor (comparable to stock) and it dissipates quickly (whereas before it would get worse and worse until I pushed the clutch in).
    I had no idea that it was using the "Idle" Spark Advance in that RPM range, but apparently it was. (Which explains why that table covers up to like 4,800RPM.) Not sure who considers that "Idling" but...
    Dec 2018
    Spokane, WA.
    13
    Thanks for the update. Good info.
