I'm in the process of dialing my idle air flow and primary VE with the scanner. I have the maf disabled to do this. The problem i'm having is with smoothing my idle but when i copy the data from idle desired airflow to my tune file and flash the truck will not start up and run. I have to set my 140,176,212 range up to 15 g/s.to get it to fire and idle. The data i collected is in the 11.5 and 11 g/s range. I feel like i'm missing a table or a step to do this properly. Im waiting for the truck to cool down and i will do another log and add it to this post.
