Hello,
How is HPtuners calculating Manifold Temp in latest version of the scanner. I know its not a sensor as my car does not have an intake manifold Temp sensor.
Thanks,
Rob
2014 Cadillac ATS LTG 2.0 Turbo A6
Hello,
Thanks,
Rob
I would like to know this too for Gen V Corvettes.
Guess i'll open a ticket with support. Thought they monitored the forums as well.
MAT is usually the bias between the IAT and ECT sensors, cylinder charge temp bias determines the temp readout all zero's makes it same as IAT and all 1 makes it same as ECT
not sure then im use to the LS style, u can just unplug some sensors IAT and ECT see if it directly changes the MAT reading, if it dosnt change at all then not sure where its getting a calc from
Keep in mind hp tuners aren't calculating anything, they are reporting what the factory ecu is calculating. Your question should be directed to the gm engineers that coded the ecu.
