Hi Guys,
I am fairly new to HP Tuners and GM Tuning (my main tuning knowledge is in EVOs and WRXs). I have been learning a lot though on my LS3 swapped Toyota 86.
A friend with an HSV Maloo (LS3 with 1,7/8 long tube headers and Camtech 285 cam, (specs below) He has taken it to multiple tuners who incidentally gain power for him but his tip-in seems stuffed. When releasing the clutch to take off with match gas pedal the engine stumbles and almost stalls (occasionally it has). I got a log of it and you can see some weird behavior in it (he takes off from stand still 3 times in the log).
Can someone take a look and tell me what they think it is? It looks like it pulls heaps of timing just off idle and and the o2 sensors look like they lean right out. The car performs perfectly once moving. His tuner wants him to drill a bigger hole in his butterfly (currently 10mm) and he would like some advice and I would like to learn. He is on a SD tune. I have tried some small things like spark smoothing to no effect. I would like people who are better versed in GM tuning to point me in the right direction.
Cam Details:
Part No: CT287149906
Description: Our most popular cam in stock or modified engines. Brutal mid range and top end. Requires 3.9:1 diff ratio, good exhaust & custom tune. RPM RANGE 2600-7000
Specs: 285˚ 285˚ 233˚ 233˚ .591" .596" 113˚
Link to Product: http://www.camtechcams.com.au/chev_sb_gen3_rollhyd.html
Log: Pat's Maloo Oztrack Tune Log XX.hpl
Tune: Pat's 2010 Maloo 6.2lt oztrack12.hpt
Thanks in advance guys,
Camo
