Sorry for the new post, but since this is a little different from my A/C Fan post, I figured I make a new one.
I need some guidance right now as I'm still new and learning each day..
Doing research, it's been said to use the Camaro/F-Body calibration if I want the fans to enable/disable when the A/C is working.
That being said is it just as simple as going to System-> General -> Platform Type, and changing 'GMT800' to 'F-Body'?
Or do I need to find a stock tune from the HPT repository and use it?
Lastly, looking at the PCM pin-outs differences between the Camaro and Truck PCM's from 99-2002, they are virtually the same other than changing a few pins for the TPS & Map sensor? or is there more to that?
