Results 1 to 9 of 9
Thread: Is there a way to control timing by gear?
    Jan 2016
    332
    Wondering if there is a good way to control timing by gear? I would guess its through the torque management functionality. But I don't really know how.
    My reason for asking is because my car routinely gets some knock in 3rd gear that doesn't show up in 1st or 2nd. I suppose it's more load on the engine. Wondering if there's a way to pull some timing when hitting 3rd.
    The car is a 2010 Camaro supercharged. Manual.
    2010 Camaro LS3
    Kenne Bell 2.8 Supercharger
    BTR stage 3 PDS Torque Cam
    Frankenstein M311 heads
    9:1 forged rotating assembly
    Speed Engineering Headers
    ID1000 Injectors
    Twin return fuel fuel pump
    PLX Wideband
    HP Tuners
    Wondering this too, had same issue with my supercharged ecotec. Would like to see any input on this by some of the more knowledgeable people
    May 2016
    1,134
    Do you see higher cylinder airmass in 3rd? If so there's your solution.
    Jan 2016
    332
    Quote Originally Posted by ridenrunwv View Post
    I'll have to look at this. I think I see what you are saying...if I'm only getting to this higher state of cyl air mass in these higher gears then I can just pull the timing down in that part of the main table?
    I'll check my logs...
    Tuner in Training bigwillys58's Avatar
    Nov 2008
    Springfield Tennessee
    20
    Quote Originally Posted by cc-rider View Post
    That is correct
    08 GMC rcsb 2wd. 4.8/4L80e with a dollar store turbo.
    best so far of 7.25 @ 97.4 1/8 mile
    Jan 2016
    332
    Well...checked my logs. Unfortunately, I am not seeing higher cyl air in 3rd gear as opposed to 1st and 2nd gear.
    So...back to the original question. Can timing be controlled by gear?
    May 2016
    1,134
    I am unaware of a way but I've honestly never spent that much time looking.
    Australia
    1,996
    being manual the ecu doesn't know what gear u are in it can only guess, is it actual or just burst knock ?
    May 2016
    1,134
    It can know gear based on speed and a lookup table. I am just unaware of timing modifiers by gear. Most common things modified by gear would be WGDC or boost. Haven't really come across anything in experimenting with different platforms where timing is modified by gear unless of course you're hitting higher load in higher gears and can just modify the main timing table appropriately.
