In the SCT Advantage suite, the description for knock sensor sensitivity says "A smaller number in these tables reduces the sensitivity of the knock sensor for that cylinder".
The description for that function in HPTuners indicates "This defines the detection threshold for knock. If the knock signal minus the noise floor is greater than this then knock is detected".
Does the description in the SCT Advantage software hold true for HPTuners as well? In other words, if I increase the values in the HPTuners software, does that also increase the sensitivity of the knock sensors?
