Oh I gotcha. If you are referring to the [ECM] 12661 Alcohol Adder table then that is definitely not where you want to put your actual timing adjustments. I'm sure you know but that particular adder table is for the torque timing table which deals with tq calculations. From my experience it doesn't actually adjust physical spark advance.
