Page 10 of 13 FirstFirst ... 678910111213 LastLast
Results 181 to 200 of 251
Thread: VCM Suite 3.4 is here!
  1. #181
    Sep 2016
    16
    Quote Originally Posted by lt1z350 View Post
    So last night went to do a log and 3/4 of my channels go dark and won't see or use them once I connected to my vehicle so what went wrong? When I first hooked up the scanner it went through a huge update listing all available new pids before would connect sort of like when updated from 2-3 series and lost it all last time and had to go and redo all my stuff. Sure it is something I am missing as others seem to have no issues.
    Was this issue resolved?
  2. #182
    When I apply a custom operating system, after I save and reopen the file the operating system box is blank, not sure if this is intentional or a bug with 3.4?
    I have version 3.4.40, which I downloaded today.
    PCM is from a 2002 Camaro, operating system 1253002
    2010 GXP Maloo ute, LS3, 6L80E.
    MM heads, 240/252@50 solid cam, 12.75:1 compression, 4500 Dominator converter, 3.46 rears.
    Shooting for 10s eventually.
  3. #183
    Banned
    Jul 2015
    Poland (Europe)
    174
    this is normal, after changing custo OS all other are blanked out
    best reagrds
  4. #184
    I have 2 bar tune .how do I get psi kpa to read correctly .i added new channel 2bar
    learning
  5. #185
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Read correctly in tune or log? Post screenshot, log, tune.. something.
  6. #186
    Dec 2010
    Richmond, VA
    40
    Can we get the A6 transmission torque based pressure adapt and volume adapt values added to the scanner? This would really help with calibrating these.
    SHUETUNING
    Powertraincontrolsolutions
  7. #187
    Advanced Tuner Ranger6202's Avatar
    Oct 2013
    Wyoming
    346
    I may have missed it, but have we got support for our Non-linear Wide bands yet? I have an AEM 2300 series that i really don't want to give up. Was trying to set it up in my scanner tonight and looks like nothing has changed.
    Custom '85 Crew Cab Short Bed Lq4 swap
    '06 Turbo Vortec Maxx
    '87 Military K3500 LQ4 swap
    '96 K1500 lq4 swap, Howard Cam (216/224 @ .050, .551/.551, 114), Centerforce Dual Friction
  8. #188
    Jul 2015
    925
    Quote Originally Posted by Jay@HAP View Post
    Attachment 65384
    can you please change this back to the way it was in 3.2? It is damn near impossible to compare inverse tables with this setup. You also can't change the units, g to mg, etc.
    Still would like this changed.....
  9. #189
    Feb 2006
    South Carolina
    1,525
    You have to change the axis units prior to opening the axis editor. Right click, "Column Axis>Units" or "Row Axis".
    Jaime
  10. #190
    Sep 2002
    Chicago, IL
    6,397
    The axis editor will use the units that the axis in your table is using. Change the underlying table axis units, and the axis editor will use those changed units.
    I'm not sure what you mean "impossible to compare inverse tables". Can you elaborate a little more? Pictures would help as well.
    We got this guy Not Sure, ...
  11. #191
    Jul 2015
    925
    Quote Originally Posted by Keith@HPTuners View Post
    Will do. "inverse table" may be the wrong way to describe it, I believe I should have used axis instead.
    On a Dodge, when I change injector data or manipulating fueling I change the InjPW vs Fuel Mass table and the Fuel Mass vs. InjPW table.
    After making changes to the injector pulse width in the InjPW vs Fuel Mass table, I would open up the Fuel Mass vs. InjPW table, click on the InjPW axis and paste my changes from the first table then compare them (like in the pic).
    Before 3.4, the InjPW axis data would display in a column which made it very easy to compare it to the other table. In 3.4 the axis is displayed in one row with the graph.
    I hope this explains it a little better.
  12. #192
    Sep 2002
    Chicago, IL
    6,397
    You can still do this.
    Copy the axis, paste it in... copy the other axis, paste that in..
  13. #193
    Jul 2015
    925
    Yeah I get that. My complaint is how it's displayed.
    Thanks.
  14. #194
    Sep 2002
    Chicago, IL
    6,397
    Ok. So you want to be able to view it in a single column, instead of a single row. Is that correct?
  15. #195
    Jul 2015
    925
    Correct, like it was prior to 3.4
  16. #196
    Jul 2015
    925
    Quote Originally Posted by ElecTech View Post
    Thanks for the tip, I appreciate it.
  17. #197
    Tuning Addict
    6,873
    Wasn't sure if you knew about it or not Keith, but apparently the Desired Throttle Map and Desired Throttle Airflow pids aren't working in the scanner anymore...
    Is there any update on being able to change the units in the axis on the torque model editor I know y'all have a lot going on, so won't bug you anymore about anything else right now...
    Thank You
    ~Greg Huggins~
  18. #198
    Tuning Addict
    6,873
    OK, so I was trying to add a second 30-0333 wideband into my scanner today... No matter what it will not recognize the second wideband as being hooked in... The second OBD controller tab will not pop up even after repolling... Something else - channels are hit and miss - may work, then repoll and lose 80% of them? Don't think I'm doing anything wrong, but who knows? Anyone else having issues?
    ~Greg Huggins~
  19. #199
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Probably a stupid question but I assume you updated the settings on the wideband for it to be WB EQ Ratio 2 and not another one on 1?
  20. #200
    Tuning Addict
    6,873
    Why of course not I was going by AEM's youtube instructions for setting up a dual setup - never mentioned anything about having to change the settings on the wideband itself... Guess that's what I get Don't have the directions handy, but assume this is pretty simple? Minor setting change? Still having other scanner issues, but perhaps I've just got too many channels?
    This would explain why both work individually...
    Thanks Carson
    ~Greg Huggins~
