Thread: Tune 12208322
    May 2016
    5
    Tune 12208322
    Im having a hard time logging into the repository. Could some pull this tune for me? Trying to get this thing running.
    13,598
    Stock file.
    May 2016
    5
    So its telling me I have to pay for the license again even though I already bought a license for another 12208322 ECU. Im getting a x7f error when I am trying to reflash the ECU with the updated tune file I downloaded from the ECU.
    13,598
    Well yeah, that tune is pulled straight from the repository. You don't have a license for that file because it's from a different /vehicle computer. 12208322 is just the OS, not the number off the computer.
    If you already have the tune off the vehicle you are using and a license for it, you should be able to make any changes you wish the re-flash it to the PCM with your MPVI. I would contact support with your issue, they will likely help you more.
