l contacted support no response as of yet. Very strange it flashed no problem did key cycle yet know no start and wont even communicate with PCM flash or read. Battery is good I used HPT to flash truck
HPT most likely wont respond until tomorrow, being today is a holiday.
But what file did you use to flash the truck with(when it stopped working)? Did you use the file that you have attached in you original post? Or is that the file you get when you try to do a read?
The file flashed in no issues 100% did the key cyle as asked on screen. l used the modified file l just posted. l tryed the original know that wont even flash in
