Page 10 of 87 FirstFirst ... 678910111213142060 ... LastLast
Results 181 to 200 of 1732
Thread: VCM Suite 3.0 Is Finally Here!!!
  1. #181
    Sep 2002
    Chicago, IL
    6,397
    Quote Originally Posted by GPGTP View Post
    I don't really care too much about the configs but did I read it will get rid of 2.24?
    Yes, 3.0 will remove 2.24 and 2.25. We'll release a new 2.24 that installs side by side with 3.0 soon.
    We got this guy Not Sure, ...
  2. #182
    Quote Originally Posted by Keith@HPTuners View Post
    VCM Scanner 3.0 will pull data from GM vehicles going all the way back to 1996 at a much faster rate, 2004+ vehicles should be night and day difference.
    Yes I am fully aware that you like the new scanner better.
  3. #183
    Feb 2015
    11
    does remote logging work on 3.0?
  4. #184
    Nov 2014
    25
    Is there a BE table in a 3.0 custom OS? I thought I read something about removing it in 2.25.
  5. #185
    Jun 2011
    Montreal, Canada
    758
    One more question.... I set up a user defined fuel pressure sensor ... when I add what I think is the right thing to the chart.... the parameter shows as "pressure ratio". Does that sound right ?
    2007 Corvette C6 Vert. A6
    LME LS402, Pat G custom cam, ATI 10% OD Damper
    Circle D triple disc 2600, 3.42 Diff
    YSI, 3.0 pulley, ID 1000's
    Alky Control Meth,
    ARH 1 7/8 headers,
    1009 RWHP @ 7000, 817 RWT @ 6000
  6. #186
    Sep 2002
    Chicago, IL
    6,397
    Quote Originally Posted by LT1Z View Post
    That's not what I mean.
    Physically/Functionally, it will actually get data from the vehicle at a much faster rate.
    The data sampling and resolution will be better in 3.0 than 2.24 for just about every vehicle, and for many, by a drastic amount.
  7. #187
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,214
    I'm still waiting for my FJO Racing wideband to be added to the 3.0 scanner.
    Russ Kemp
  8. #188
    Exactly. I get it. You like it better because it is faster. I just want the option to update 3.0 without it wiping my copy of 2.24.1172 every time I download a new build of 3.0 which is likely to be daily.
  9. #189
    Nov 2007
    MI
    686
    I don't have a huge issue with having to make new configs but I do have an issue with not being able to review my old log files. Hopefully getting the 2.4 that will work in tandem is of high priority. I will probably hold on upgrading till that is available.
    2018 Camaro SS, Maggie 2650, 103 TB, Big Gulp, E85
  10. #190
    Dec 2005
    Texas
    254
    holy hell! yall took a big swing at it this time
  11. #191
    Senior Tuner Mep_q8's Avatar
    Mar 2006
    Kuwait
    1,564
    Good Stuff!
    Bader Norris
    MEP Tuned
    Telephone: +965-55446651
    Email: [email protected]
    Instagram
  12. #192
    Sep 2011
    Portland, OR
    523
    Been using 2.25 for months tuning Dodges. Even did some beta testing for the HPT folks.
    It just kept getting better and better.
    3.0 will be cool.
    We do need 2.24 for old logs though.
  13. #193
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    A bug I reported a month ago isn't fixed in Editor by the way.. just noticed
    To replicate:
    Open a tune.. open a compare file
    Make a change in main view
    Switch to "show differences"
    Hit ctrl+Z to undo the last changes
    It puts the "old" values into the differences window which makes the main display totally wrong
    and one more question.. any plans to make a "compare" view in virtual VE editor?
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
  14. #194
    Hi guys, I don't spend a lot of time posting on the forum, but I have spent the last 12 years building configs for various applications.
    There is not a hope in the world that I can go back and rebuild all my configs & to be honest with you I'm not sure I remember how to!
    As I workshop & I do believe I speak for most, this is something that you need to take in to consideration & find a way to allow us to export our current configs back in to the new scanner.
    Good on you guys for doing the update, I do like the new platform & understand a lot of the new changes & they are for the better. But you cannot simply ask us to rebuild our tables, it's just not good enough.
    Please find a way to fix this.
    Independent Motorsports
    Shop 3/32 Vestan Drive, Morwell. Victoria. Australia 3840
    (03) 5134 8822
  15. #195
    Dec 2013
    EDM, ALBERTA
    30
    Someone should make a really easy to use VVE math channel and post it up. For it to be added to 3.0.
    Also itd be really cool if the sensors used in the scanners spark timing table and the editors timing table were the same. Editor uses spark airmass g and scanner uses map kpa. Or did i not pick my units correct? Just seems odd that a graph that directly influences what a tuner tunes timing with needs to be changed right from default. Unless i happened to mess somthing up?
  16. #196
    Senior Tuner mowton's Avatar
    Mar 2007
    Florida
    3,772
    Thank you!!! Finally we can fix this bug.
    It will be fixed in tomorrows 3.0.6
    All right, looking good. Thanks again Keith, I can just imagine how your life must be during this development/transition. We do appreciate your effort very much and hope for a quick resolution
    Ed M
    [email protected]
  17. #197
    Sep 2002
    Chicago, IL
    6,397
    3.0 can open up 2.24 log files.
  18. #198
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Quote Originally Posted by roland1 View Post
    What do you want it to do math parameter wise? I don't think what you're asking for makes sense.
    Just change the spark timing table to match what your ECM uses....
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
  19. #199
    Nov 2010
    15
    Anyone else having log on issues with the site? I'm trying to get in to download the new version and first I figured I may have been putting the wrong password so I did the reset took forever to get the email and still no dice.
  20. #200
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    I bet the site is getting destroyed right now with downloads
