Results 1 to 7 of 7
Thread: Full Rich after WOT
    Aug 2014
    Central, LA
    737
    Full Rich after WOT
    I have a 2012 Corvette with a small cam and boltons.
    Everything has been fine until yesterday when I got a service active handling light with p0106 Map out of range. The car is tuned maf only right now since I only really have time to do scans on my commute to work so the VE is a little out of wack. I went ahead and set p0106 to no error reported as well as changed the min temp for the test to 299* f and max to 1*f so that I wouldn't run into that issue while I'm on the maf only. I just wanted to give that bit of info in case it was important.
    Last night I did a little wot pull of 3-4 and everything was fine...lambda looked good on my gauge (dashlogic) but when I let off and let it coast down for the stop sign coming up I noticed it was still reading ~.8 lambda but commanding 1.0 and after it went back into closed loop after PE the stfts were -20 for both banks at part throttle and idle. I shut the car down and restarted it and all was fine once it went into closed loop again since I didn't end up in PE again.
    I'm going to do some scans today if the weather permits to see if I can make it repeat this behavior so I don't have any data as of now but I wanted to know if there was anything quickly I could look at that would cause this?
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Log.
    Aug 2014
    Central, LA
    737
    Coming up tonight. Was trying to get an idea since I couldn't last night.
    I'll attach after I get it done.
    Nov 2009
    All Around
    3,149
    post tune and log
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    That too
    Aug 2014
    Central, LA
    737
    After logging for over an hour and using way too much fuel I haven't been able to repeat...
    I'll go try some more after the temp drops a bit tonight.
    Nov 2005
    Someplace high in the Himalayas
    770
    If iat sensor fails, it will go crazy rich to be really safe. I think maf failure does this also.
