car dying. . plz help.
one of the o2 sensors has very little activity.. cocamaro first test.hpluld this cause the car to die after a minute.. idles fine until this point.
Gotta post some details on your setup, and a tune file would be nice too. Post your config with a log file as well.
Just based on what I could see in my config, is your MAP sensor reading at all? Plugged in? It was just at 10kpa the whole time I could see. Looks like you're running lean based on the stock o2s and the stft.
re;
98 ls1. stock cube. stock 243 heads. ls6 intake. ported tb. there is a loud whistle when car is idling? possible vacuum leak? . cam is btr stg 3. camaro new test.hpllogan camaro use this1.hpt
there is the tune and new test.
map sensor not responding at all.. gonna check that out
a loud whistle at idle is probably a vacuum leak. seeing as your map sensor wasn't showing anything, Im guessing you might wanna start by looking around in that area... lol
map sensor wasnt plugged up. got that fixed
