Results 1 to 20 of 35
Thread: 2013-2014 Mustang Automatic in gear limiter
    Jul 2008
    39
    Hi All,
    Can anybody tell me what limits the engine rpm to ( 2000 ) when in gear and the brake is applied ! This is what stops you from heating up the tires or doing a burnout . Any help would be greatly appreciated.
    Jul 2008
    39
    Hummm ! nobody knows ???? Interesting
    Ford calls it BOA brake over acceleration...I'm pretty sure getting rid of some of the torque management or resetting to higher number on some of the torque value limits will do away with it....
    Jul 2008
    39
    Well i think i diabled all the torque management i can find and it still limits rpm to 2000 !!!! Anybody have anymore advice ??????
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,214
    Raise the Inferred Movement RPM in the Trans General tab.
    Russ Kemp
    Jul 2008
    39
    Thanks Russ I will try this
    Nov 2008
    Tampico Bay, Mexico
    220
    Sorry for crashing this thread but Im also having this trouble and i already raise the inferred movement to 8000rpms and still have this same.2000 limit any other ideas is a 2013 gt auto
    all the way from Tampico bay Mexico
    Jul 2008
    39
    Yes I also just did this and it did nothing !!!!! I think there is a parameter missing we are not seeing ??? Thats all i can think of !!!
    Oct 2007
    Crawfordville, FL
    2,439
    Quote Originally Posted by efiv6 View Post
    Ill double check to see what may be missing
    Eric Brooks
    HP Tuners, LLC
    Jul 2008
    39
    Ok thanks Eric
    Oct 2007
    Crawfordville, FL
    2,439
    Please post the file so I can have a look.
    Eric Brooks
    HP Tuners, LLC
    Nov 2008
    Tampico Bay, Mexico
    220
    this is my current tune
    the 22 file is my current for the street the limiter one is the no torque managmet file in that one it lights all the traction and stability control warning lights but that was my poor try to eliminate this annoying issue so please check them eric ,sultan, russ, anyone HELP cause i have a drags with cops permit this weekend and i dont wanna be embarrassed cause ill be the only one that cant do a decent burnout
    Dec 2005
    Regina, Sask.
    4,214
    Disable the trans torque truncation, and also try disabling the master enabled under torque reduction.
    Russ Kemp
    Jul 2008
    39
    Thanks Russ I tried all that and it still limits RPM to 2000 when brake is applied !
    Eric, I will post a copy of my stock file for you in the morning
    Jul 2008
    39
    [ATTACH]46902
    Here is a copy of a stock 2014 Mustang 3.7 V6 Auto. file
    Jul 2008
    39
    Eric did you find anything ?????????
    Oct 2007
    Crawfordville, FL
    2,439
    Update, then look under Engine > Torque Management > ETC Torque Management > Torque Max vs. RPM
    Raise the right side up to the max (10,000 Nm)
    Let me know if that does not correct it.
    Eric Brooks
    HP Tuners, LLC
    Jul 2008
    39
    Eric, no this did not correct the issue still limiting rpm to 2000
    Oct 2007
    Crawfordville, FL
    2,439
    Scan it, and make sure you have Torque Source in the config. Let me see what it is doing.
    Eric Brooks
    HP Tuners, LLC
    Jul 2008
    39
    Ok will do
