Thread: 2006 6.0 commanding lean
    Jul 2011
    21
    I have a 6.0 lq4 that is in a Jeep. A friend of mine did the engine swap and I turned off emissions, vats, and rear 02's. The engine is all stock except the air filter. It runs and drives great. I have a couple questions, it came up with a code for lean fuel trims. I did a scan (attached) and it has a lot of trims and at one point it was commanding 16.0 AFR. What would cause the lean commanded AFR? Do you see anything that would cause the high fuel trims. I am new to tuning and have only worked with some old black box ecm's. Any help would be greatly appreciated.
    Grand Rapids, Michigan
    13,609
    If you changed the intake setup, you will likely need to do a maf tune.
    Otherwise seeing +16.4 alot means you have a vacuum leak somewhere.
    Feb 2009
    1,931
    Please explain to me how the PCM commanding 16:1 means he has a vacum leak.
    OP, is the tune you posted the one in the vehicle right now?
    Jul 2011
    21
    Quote Originally Posted by mecanicman View Post
    Yes that is the tune that is in currently.
