How many logging runs does it usually take to get the LTFT's in line?
I've made 4 runs so far, and my LTFT's are still off. The first run indicated the truck was running rich, all runs after have been running lean. The latest run was still showing numbers around +10. Granted, today's run was in 25-deg cooler temps, which I know has an effect.
Just wondering what the average number of runs it usually took.
I've also kept the MAF plugged in so I don't get the IAT error (P0113?), but the MAF Failure is set to 0 Mhz.
I've seen conflicting info on this part. When I do a logging run, I do reset the fuel trims, and turn on trim learning. Is this correct?
