I have been experimenting with Transient Fueling for some time now and found varying and inconsistent results. I can alter either or both Evaporation Factor and Transient Fuel Mass Gain/Impact Factor and initially find expected results and can verify by logging IDC and obtain satisfactory fueling on immediate throttle transition into boost. What I can not understand is why the expected results will only work through 1 or 2 key/start cycles. For whatever reason the IDC reverts back to percentage of change comparable to stock setting.
Is there some kind of adaptive or learning feature in the computer that we don't have access to? The values in the cells reflect just as I input.
I can Log on first start up after changing settings and see my IDC increase 10 to 90% or higher depending on what value I input and will repeat those values every time I hit the throttle during the first startup cycle. I can hit throttle 10 times and I will see IDC shoot up 10 times and be very consistent.
I then turn ignition off and restart engine. Start scanner and while logging find IDC reverts back to values just like I never made any changes.
Can anyone explain?
