Hi,
I'm tuning a friend's 2007 Z06. It has 440CI Engine, Heads, Cam, Intake and an NW102.
I'm facing some issues that I would appreciate any help on. Here it goes:
- I'm having some startup issues. The car starts fine, cold or hot. However, it takes around 10 seconds of bouncing around and almost dying before it settles.
- The car bucks really bad upon take off. You have to give it lots of throttle in order to move and it will buck very bad before moving. It also sounds very bad when bucking. Almost sounds like fireworks.
- When playing around with WOT (Not calibrated yet) The car will start leaning out after 5500 RPM. No matter how many times I calibrate the MAF it will lean out. I'm doubting two things here, one is that I need more pump. IDC is @ 75% all the way. The second things that I'm doubting is the injectors. Owner says they are FAST 60# but I don't think he's 100% sure. I took one injector off and it only says FAST and there was no part number or anything to verify.
- Why is the car not commanding 14.7 @ Idle and normal driving?
I'm attaching a log and the config.
I appreciate all the help!
