I've been playing with this thing all day. It's the first E78 I've done that's beyond a bolt on vehicle, so it's proving to be a bit challenging.
The truck's had a lean tip in problem all day that I finally seem to have fixed through PE enable parameters. Though in this last run I made, you will see in the data log file that it remained in CL during the WOT portion of my run. :-/
The truck has Deka 60# injectors w/ a Volant CAI that houses the factory maf in what appears to be about a 90-95mm housing.
Since everything on these E78's is torque based, I'm having a bit of a hard time figuring out the best method for getting 100% throttle. As you can see during the run, the throttle was fluctuating between 83-88% during the run. I was able to finally achieve this by adjusting the driver demand settings above 44%...
I'm afraid to adjust these tables too much though, because if you can see after second gear I let off (which shows as a decrease in MAF flow)... but the TPS remained in the 80+% range.
Anyways, I just need some second opinions and some help from anyone who has done more than a couple of these and knows what needs to be done. I know the tunes a mess, so don't be too critical... I will clean it up after I figure out the issues.
thanks in advance.
