Page 3 of 3 FirstFirst 123
Results 41 to 55 of 55
Thread: 09 Z06 Blown odd behavior at wot on dyno
  1. #41
    Mar 2012
    I was at 52psi under wot at 9.5 lbs of boost. Air fuel 11.2 on the gauge. Car makes 567/520 with a procharger d1. Idcs are 93%. Ls9 injectors. Desk this sound right?
  2. #42
    Senior Tuner IDRIVEAG8GT's Avatar
    Aug 2010
    Roswell, N.M.
    1,956
    Quote Originally Posted by thebeast View Post
    Yup sounds about right on the money. I'm at 627rwhp, LS9 injectors, 72psi rail pressure, and 88%INJDC.
    Gray Ghost- The abomination. 2007 Chevrolet Silverado CCSB. 98mm turbo, nitrous, 428LSX, Rossler 80E with a brake. Finally finished. 23 psi, no numbers, Slow as hell.
    PBM G8- Aluminum 364, twin Precision 67/66 turbos, 6L90 trans swap, CTS-V/Vaporworx fuel system, slowly making progress.
    Dads 2011 CTS-V- Stock bottom end, stock heads, LS9 cam, pullies, ported blower, ported TB, D3 goodies, and lots of nitrous.
    618/618 motor
    906/862 spray
    Caterpillar 50 Forklift- Duramax swap
  3. #43
    Dec 2011
    Clovis, CA
    374
    We were gonna get the id1000's because if we build a shortblock stroker, and add more boost, we dont want to spend 2000 on injectors, and figured buy once, and do it right the first time. No?!?
    Thanks,
    Dustin
  4. #44
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,863
    FYI, 1000s won't fit the Whipple kit. Too big. You have to use 850s or 2000s.
    http://www.dsxtuning.com
    Just say no to bull s***.
  5. #45
    Dec 2011
    Clovis, CA
    374
    We figured that out but thanks, went with the id850's. We called them directly for more info. Great guys down there. Lots of info.
    Thanks,
    Dustin
  6. #46
    Aug 2010
    Roswell, N.M.
    1,956
    If you need more injector than the 850 requires you might as well go to a 16 injector setup and Alien Intake from Tom Nelson and a different ECU. Lol.
    618/618 motor
    906/862 spray
  7. #47
    Jul 2005
    271
    Quote Originally Posted by IDRIVEAG8GT View Post
    Such a sick looking manifold
  8. #48
    Dec 2011
    Clovis, CA
    374
    Good thought, but with a whipple 2.9 sitting on top, cant quite change the manifold so hopefully it doesnt do this to the new injectors
    Thanks,
    Dustin
  9. #49
    Mar 2008
    St. Louis, MO
    4,863
    Or just use ID2000s.
  10. #50
    Aug 2010
    Roswell, N.M.
    1,956
    Steck I love injector Dynamics, but the way Nelson has it panned out in his Alien Manifold it's just spectacular, and efficient.
    618/618 motor
    906/862 spray
  11. #51
    Aug 2010
    Roswell, N.M.
    1,956
    Quote Originally Posted by Asylumwarp View Post
    Awe hell, I thought we were going to build 1,500 horsepower with some of the Nelson Mirror Image turbos lolololol.
    618/618 motor
    906/862 spray
  12. #52
    Mar 2008
    St. Louis, MO
    4,863
    I can't imagine that's more cost effective let alone worth it aside from flare
    Learn to multiquote, noob.
  13. #53
    Aug 2010
    Roswell, N.M.
    1,956
    When you get a product like that it's worth every penny. Not to mention having the fuel pressure regulator built in to the back of the manifold is pretty trick as well.
    All of the injector bodies are built towards the inside of the housing so you can't see that mess of wires, and also the secondary set is supposed to be devoted for what's called Octane on Demand. They're supposed to mix race gas, alcohol, nitro methane, or whatever else you want added into your fuel for high performance applications. That way you can street drive your 1,500+ horsepower car. Oh joy!
    Learn that there are other products that are just as cool as your injectors, bud.
    618/618 motor
    906/862 spray
  14. #54
    Mar 2008
    St. Louis, MO
    4,863
    No OBD-II = not street car
    Either way, needing more injector than 850s will provide doesn't warrant a custom intake manifold, a second set of injectors, and a standalone.
  15. #55
    Aug 2010
    Roswell, N.M.
    1,956
    Lol, no, tell that to Rex here in town that has his all mighty 1500+rwhp Supra. He feels as if the car is totally street even though it runs on a 70/30 mix of 116+93. *Chuckle*
    We have differentiating opinions, but eh, that's what makes the world go round'.
    618/618 motor
    906/862 spray
