Results 1 to 8 of 8
Thread: Spd Lmtr off OK/Speedo Mtr still limited
    Feb 2011
    4
    2006 GTO, cam, cold air, headers, etc. tuned by "MASTER!" tuner. We turned speed limiter off and car will run up there fine. Trouble is the Speedometer (both the number and the dial) go to a certain point (ie 155) and don't go further even though the GPS (and definitely we know)is showing faster. Any ideas?
    Did search the forum. Couldn't find anything. If someone has already addressed this issue, thanks in advance if you'll let me know.
    Advanced Tuner c.u's Avatar
    Jun 2010
    Eville, IN
    282
    you have them set like this.
    28,313
    PID is limited to 155mph in the scanner, no workaround for it currently.
    Feb 2011
    4
    Thanks viper2fast. Did find that one but again thanks for the reply. Ditto to c.u. We tried that. Last, but definitely not least, THANKS BILL. Don't know how you keep up with all these threads and posts. Purposely did not pm you yet here you are. Just awesome. That's what you get with Hp Tuners guys and gals!
    Jun 2010
    Eville, IN
    282
    homeband are you talking about the scanner or the car`s speedo?
    Feb 2011
    4
    The actual Speedo on the car. Irritating. Either have to hook up the scanner or hook up a Garmin gps. Kinda crummy with all the technology that such a sweet car as a 2006 GTO can't have the speedo tell you what the car is doing. It would be safer to let us know than to keep us "limited" in knowledge.
    Jun 2010
    Eville, IN
    282
    Ok turn the key on while holding the mode & set button`s at the same time. When you see the serial number use the mode button to scroll down the list. Look for over speed use the set button to turn it off. let me no there may be one other thing to look at.
