Reason: screwed up
'99 Silverado ECSB w/5.3, Patriot Performance Heads (2.02in 1.57ex) milled .050, LSXrt intake w/FAST 102mm TB, Comp/EPS Cam (226/230* dur .598/.600" lift 113 +2 LSA), 44# injectors, LS7 Lifters, Stock Rockerarms, Double Roller Timing Chain, ARP Head & Rod Bolts, HV Oil Pump, Vigilante 9" Converter 3600 stall, FLT Level 5 4L65E, K&N 77 series, Pacesetter LT, No Cats, Magnaflow Mufflers, True Duals, TB Bypass, Truetrac, 4.10's, E-Fans, HP Tuner
'10 Camaro 2SS/RS RJT, L99, A6: Stock
