Finally got to read my minivan today...took 3:06 to read, went well overall and the van started without issue after reading. Now I just need to bug Chris to map it so I can test writing lol
are the 06 jeep srt8s can or bus? im ready to test if you need someone,
also with this change the tcm also.? shiftpoints, tm, ect.
2002 Camaro SS, Twin S480s
2006 Corvette C6, Twin Turbo
1991 GMC Syclone, LS/AWD/AC
We currently don't have any Jeep vin info added to our source so I don't think our software will read them yet. Only Dodge/Chrysler.
Regarding tcm support we are working on supporting the ones where the tcm is located in the pcm, not sure if it'll be in the initial release but we do want to be able to support them if possible.
Yes, I'm aware.
Chrysler and dodge support for which model of cars? 300C, Neon, Charger, Challenger.....etc
As i have access to many of the Chrysler and Dodge fans, what exactly you are looking for, i am sure i can help.
And how to idenify if the car has NGC3 or CAN? is it by the year of manufacture or what?
High Way Garage
Location Saudi Arabia - Jeddah
Phone : 966 504 655 105
Custom Tuner:
GM - Ford - Chrysler - Dodge - Jeep- All Europian Cars + Ducati Bikes
HP Tuners
SCT Dealer
Diablosport Dealer
Sniper Delta Force Dealer
Viezu Dealer
Alien Tech Dealer
Dynojet 224xlc dyno soon
Custom Tuning via Email Available
NGC3 is CAN based.
I have a full list of all NGC3 based applications, mainly right now we are looking for reads for mostly 2005-2006 300c, Charger, ram as thats what we have most of the vin info for already in our source code.
Our software should also be able to read most SRT4 neon's, some dodge minivans(I read mine), dodge dakota, etc. I don't think Jeeps will read out yet because we haven't added much(if any) of their in information into our source code yet but that'll come in time(we've already got some 40 dodge operating systems in) as we've already got enough work on our plates for a while from the looks of things.
I am looking to programmed out an EGR on a 2005 5.7 hemi is the beta software able to do this
I have a 2006 300C that will be at our shop soon for a procharger install. Do you need a read on this?
I have a 06 4.7 Ram with PCM serial number 56029898AF. Any chance I am supported yet or you need a BETA, let me know. The truck has a 5.7 Hemi in it running on a stAck of two other tuning setups and could really use a good tune to dial in both engine and transmission.
I have the latest beta...
Tried to read the PCM on a 06 Chrysler 300C SRT-8. It failed the checksum.
The cal ID is... 05030232AB
Also... This vehicle is currently tuned with Diablosport.
Edwin P. Gregory III
SOUTHERN HOTROD, LLC
2230 Richland St.
Kenner, LA 70062
SOUTHERNHOTROD.com
888-BIG-HEMI
Send in the file along with a vcm suite infolog while connected to the vehicle in question, pretty sure diablosport disables the checksums in everything it tunes so we likely won't be able to support the file unless the pcm is put back to stock.
We've explained this error here http://www.hptuners.com/forum/showthread.php?t=25138
Do the other vehicles have the same injector characterization tables as the 2006 300C sample file that comes with 2.23.193?
Paul Yaw
Injector Dynamics
We haven't looked yet, but more than likely they will be similar.
