Ok, a friend of mine just got his C6Z running with the built motor. Specs:
Huge cam
Ported heads with 12.9:1 static compression
LSXR 102mm manifold
NW 105mm throttle body
RPS LSX BC2 clutch
When you start it up, sometimes the idle sits there and swings back and forth until it goes into closed loop. My car doesn't do this, but I also have a stock throttle body, despite a very similar cam and the same clutch. I don't want to force closed loop to come on sooner as a fix for this. Anybody have any ideas? I've tried playing with the minimum idle airflow and statup airflow to try and smooth it all out, but have had no luck. If you let your foot off the clutch while in neutral, it'll steady up (probably from the inertia of the transmission).
