Am I missing something here? The highest number I can input into this spot is 63 and I have 83# injectors....
2018 Infiniti Q60s
2004 350z/LS2: ERL 434ci, 11.8:1,TFS245cc,262/266@113+3,Fast102,NX 102 plate,60#injectors/return w/twin 255s
Old setup: CNC'd317s, Fast 102, 228/228@114, PT88,83#injectors/full return system. 10.84@138
Its the pcm's hardcoded limit, no easy way around it other than fudging the airflow tables.
So I really can't use these injectors?
2018 Infiniti Q60s
Search "IFR scaling". Lots of info out there but requires all airflow and torque calculations to be scaled to the same amount as the IFR table scaling.
As others said, it is possible, do more searching. But it is a PITA! Its GM's fault!
pm me your email ill send you a document that will help with scaling
You're working too hard. Why not simply scale the voltage table instead?
Its not that hard to do. You need to scale any table that is references buy grams/sec or lbs/min.
Full Service GM Late Model Performance Facility
www.redline-motorsports.net
Follow US on FACEBOOK!
Follow us on Instagram! redline_motorsports
Is there any way to simply scale the injectors on my stock tune to get the car just to start to make sure everything is set good?
2018 Infiniti Q60s
Back to this whole thing...I was told IFR vs. IAT will successfully work in upping the injector size...
2018 Infiniti Q60s
noone?
2018 Infiniti Q60s
give it a try, it might work, because when you go FULL SD thats the secret table to tune so your car drives in every weather temp
yea, give it a shot. wonder if the IFR parameter would show the change in the scanner...
if you're going to run sd, and dont need the extra room on the maf, then it would be a simple solution...
Car runs great. I maxed out the ifr table then did 1.3072 in the ifr vs volts AND ifr vs IAT.
2018 Infiniti Q60s
Snyper, do you have the siemens 80# injectors
I read on tech from racetronix that these injectors are actually rated at 83# with gasoline, and this is with 3 bar fuel pressure, not 4 bar fuel pressure, so that would mean they would be in the 90's with 58psi fuel pressure
I'm tryin to figure out how accurate this info is so I have no issues
, thanks
2018 Infiniti Q60s
seems to work fine for me...How do I know if its not working? Im getting 14.7-15.0 at idle...A Tuner in NY uses this method on the e40 and says it works.
2018 Infiniti Q60s
log IFR. 63.5 is a hardcoded limit, the pcm can't go any higher even via multiplier/modifier.
just for the hell of it though, change those modifier tables back to 1, and see what happens...
