yes, but if i understand all this correctly,, now your commanding 14.1. if you use afr error, then its going to be off. because, your wideband will still read 14.68 .. luckly my wideband does lambda, so good bye afr!!
p.s. i also ordered an ethanol test kit to test my fuel, if anyone needs there fuel tested, send me a pm, ill do it for you, just send me the fuel!..
-Carl
