Results 1 to 20 of 27
Thread: 2009 Mustang support?
    Advanced Tuner Witt's Avatar
    Pittsburgh, PA
    380
    Does HPT formally support 09 model year? Cant seem to get mine to successfully read a tune or log the car.
    28,312
    We've had several customers read their 09 calibrations thus far, I'm pretty sure they are still in the mapping stage at this point.
    Newest beta(available through support) should be able to read the pcm though.
    -Bill
    Pittsburgh, PA
    380
    Im using beta 2.23.3323.27855. I can read the file but receive checksum errors when I try to open it. Scanner doesnt work either, it will connect but not be able to log any data.
    28,312
    Will it save the file when you click yes to fixing the checksum error?
    Will it save the file when you click no to fixing the checksum error?
    -Bill
    Pittsburgh, PA
    380
    It will save the file when I click yes to fix the error after receiving another smaller text box checksum error.
    28,312
    If you can save the file send it to support with an infolog & we'll handle the rest.
    Pittsburgh, PA
    380
    Ok, cool, thanks again Bill.
    May 2006
    Fort Walton Beach - The land of Beaches and Bikinnis
    12
    In order to avoid a new thread...When will you officially support on 09 F-150?
    99 Camaro Z28 - Kali - Bolt-Ons
    03 Silverado V6 - Stock
    BCG Tuning becuase a custom tune should take longer than 10 minutes.
    28,312
    We need some pics of the pcm sent to support including the service numbers on the pcm so we can determine if its a supported pcm.
    09' mustangs haven't been an issue but the 2 or so people that have tried to read 09 Fseries haven't been able to send us any clear pics of the pcm which is the holdup at this point. If you have access to one and want to help shoot me the pics of the pcm to support at hptuners.com along with a vcm suite infolog while connected to the truck and I'll try to get you a software version that will be able to read the pcm.
    Pittsburgh, PA
    380
    As an update Bill, I tried using the new beta that you advised which did add functionality for 2009 Mustangs however I'm still unable to log using the Scanner. I am still receiving the "Communication with the VCM has dropped" message. I am able to connect and stay connected up until the point I try to start logging. Anything obvious I'm missing or is it because of the newer year again?
    28,312
    Witt please contact support with:
    A vcm suite infolog while connected to the vehicle in question
    Your .hpt file
    The .cfg file you are using for the scanner
    A screenshot of the error you are receiving
    A screenshot of your My computer-properties window.
    Thanks,
    Bill
    Feb 2009
    Fayetteville, NC
    5
    Hey Bill Im about to tune my 09 gt500 I'm doing a few installs on it and will be on the dyno thursday. Has anyone been able to tune them yet? I was told I was able to I just wanted to make sure. If the 09 gt is having problems I figure i would aswell lol
    May 2006
    12
    Tell me exactly what you need pictures of. I will see if my buddy will let me take the pictures.
    Ben.
    28,312
    Pittsburgh, PA
    380
    Quote Originally Posted by Epic Motorsports View Post
    Not sure about gt500s but with my 09 GT I was able to use a beta version of the editor after sending support my stock file. I'm still unable to use the scanner though. Got a set of cams on hold until I can successfully log changes to the tune.
    Advanced Tuner black06g85's Avatar
    Jul 2006
    New York, New York
    277
    Quote Originally Posted by Witt View Post
    traitor
    2006 cobalt (no more turbo)
    m62 2.7 pulley, E85, 79lb/hr injectors, 4-2-1 longtube header, airbox mod, stock catback
    1998 Trans am 5.3 iron block 317 heads 88mm turbo e85 105lb/hr injectors, twin 255's.... build in progress
    2014 wrx mild tune 18psi pump gas
    Pittsburgh, PA
    380
    Quote Originally Posted by black06g85 View Post
    traitor
    iknorite?
    Good news is the editor works great outside of a few fuel pump issues. Got an update from Bill on trying to get the scanner working, hopefully it will be fixed soon. Apparantly there aren't very many decent Ford tuners in my area so it might mean a little play money on the side when I do get support.
    28,312
    Hey Witt can you shoot me an email when you get a moment regarding your scanner issues I have a couple of questions as I'm following up with everyone that has come across a scanner lockup issue using the beta on fords as we try to nail down the issue.
    Pittsburgh, PA
    380
    Email sent.
    Thanks again Bill.
    Jun 2005
    Southern FL
    2,044
    FYI, not that it has much to do with this thread, but the new body '09 F150 and the '10 Mustang use factory widebands for their O2 sensors. Pretty cool, huh?
    HPT will eventually support these pcms, so not to worry (SCT and DiabloSport do, as well).
    Formerly known as RWTD
    Toys: '22 Tesla Model S Plaid / '20 Chevy Duramax / ?20 Sea-Doo RXT-X (2)
