Results 1 to 20 of 26
Thread: map vs boost gauge difference
    Jul 2006
    Quikville
    47
    alright lately im having an issue. when i log my map and its set up for 3 bar. the scanner doesnt read as the does boost gauge does. when im in boost well say 5psi im scanner isnt reading accurate. i know im in boost the BOV goes off around 5psi. it takes me around 10 psi for the gauge to go above 105kpa. the other day they both worked the say then i make some changes to the tune and its been like that since. i also redid the map connection since it blew out of intake so now its on a barb with a hose
    another question is on my Table in the scanner it has the MAP for 3 bar on there but its measured in psi and not kpa...how can i change that?
    i also have HPT
    28,312
    Post your scanner log for review, I'll also make a demo on how to change units in the table display for you.
    Jul 2006
    Quikville
    47
    this is what im using. if you see something im missing feel free to let me know. i never done a boosed vehicle. i just want to get it close then take it to a tuner who has done boost.
    i have a autometer Fuel guage should i add that to the EIO as well?
    i have a TTA 3 bar map sensor. i just did this configuration but not sure if im right
    thanks
    :edited: i also added a configuration i was using last night
    28,312
    Looks like its logging fine to me
    Are there problem frames in the log I should be looking at? for instance frame 736 is showing 145kpa which is 6psi of boost which is what the scanner is reading so all looks fine to me, even the histograms,gauge & graph displays look fine.
    28,312
    Jul 2006
    Quikville
    47
    my scanner is reading lower then my boost gauge thats my problem. tonigh i did a small run and my wastegate open which is 15psi and the highest value on the scanner is 170kpa. 170kpa is around 10 psi. im usually around 0 vaccum and scanner is still at 70kpa where i would think it should be 105kpa
    and cause of this its throwing all my logs off so i havent had chance to actually dial in the VE in higher rpms, if you look at the one histogram it doesnt go past 80kpa
    this leads me to think its ths scanner andn ot the truck
    i also tried to right click as you did in your doctor file and i dont that. i just have the metric/imperial and insert/delete
    Jul 2006
    Quikville
    47
    heres copy of tune, maybe you can see something off besides lean
    28,312
    Why do you have your map sensor scaled to 200kpa in the editor?
    Jul 2006
    Quikville
    47
    Quote Originally Posted by Bill@HPTuners
    i ended up coping someones 2bar just to get me running and wasnt aware it was different. that should be scaled to 320 right? and for the 0v offset is that 40?
    28,312
    But you are running 3 bar so why would you copy 2 bar settings?
    Jul 2006
    Quikville
    47
    i couldnt find a 3 bar map file to compare to. im new to the whole boosted world. just trying to get my files right.
    i changed the linear to 320 and offset is still 10.33. i did a small log the boost guage matches teh Guage on the scanner along with the table my histrogram doesnt match
    28,312
    so now its only the histogram you are having issues with? If so you probably have a custom PID created that is skewing your number, fix the custom pid or delete it all together.
    Jul 2006
    Quikville
    47
    but in the log the truck doesnt seem to be going in the higher tables. honestly i just want to try and get a safe foundation so i can take it ot a tuner. i not sure about setting this up for boost
    Jul 2006
    Quikville
    47
    this is my latest log its only around the block. if you notice the histrogram doesnt match the others. also is a copy of my latest tune. if you see anything please point it out. sooner i figure this out the sooner i can get it to a dyno, so i can drive it safely.
    28,312
    Quote Originally Posted by Quik
    I guess I don't notice it, everything looks fine to me in all of the histograms
    Tuner dewmanshu's Avatar
    Jun 2005
    Maryland
    148
    Quik I notice you never go over 132kpa in that scan. That'd be about 4.8ish #'s of boost. Did you go over that on the gauge? How about your config file? Do you know how to upload it so we can see what you are trying to log? Your hist#1 g/cyl never really goes over .88 and that's obviously wrong. Are you logging the MAF PID? If so delete it.
    2K ECSB 4WD 1500 Silvy 6.0L(swapped), 2600 Suncoast TC, TransTech4L80E, '02 PCM upgrade,Patriot Stg 2 Heads,TVS1900(2.8 Pulley),custom 224/228 568/571 114+4,meth inject to wet a 75 shot of nitrous,dynatech hdrs,gutted cats,4.1 gears w/Eaton LSP,HPT-EIO,DynoJet WB, and tuned by the seat of my pants.
    12.22 @ 110.75 blower/meth/110 (76*) (radix)
    11.66 @ 115.95 bower/meth/110/50shot (45*) (radix)
    11.35 @ 117.35 blower/meth/110/75shot (45*) (radix)
    Jul 2006
    Quikville
    47
    this is my scanner configuration
    dewey, on my boost gauge ive read 15psi, and my wastegate opend up and the highest the scanner recorded was around 170kpa
    5psi is my bov and i can hit that and the histrogram wont even read that high
    Jul 2006
    Quikville
    47
    here is what im referring to. if you look at the table it shows 196kpa but if you look at the historgram you see that its only 95kpa.....now hsouldnt they both match?
    Jun 2005
    Maryland
    148
    That screen shot is exactly what you are describing. The dyncylair is even 1.3x. That seems like a scanner issue and not a tune issue, I know you said you changed something in your tune and then it happened, but if the scalers were wrong (and them seem okay enough) then all the tables would be goofy across the board. You got me on this one, unless something is wired wrong this seems like a discrepancy with the scanner. Bill? Doug? help a brutha out!
    Do you have the old tune before you changed something and it got all screwed up like that? Maybe we could do a compare.
    28,312
    Quote Originally Posted by dewmanshu
    Screenshot of the same exact frame on my pc.
    As previously stated he has a custom PID that he made that is setup wrong.
