Would anyone mind sharing some pointers on getting a good clean idle sound and wanting to stall when I let off gas quick? Ignore the wideband reading it has a slight leak before the coupler. 408 Rec Port Heads, LS3 Intake, Fitech 92MM TB, 11.8:1 Compression, BTR Stage 3 400+ N/A Cam, TH400 RMVB
new throttle body idle and light rev.hplJosh New ECU 00 SS V19.hpt00.Channels.xml00.Layout.xml
