Problem dial in VE tables when tuning for SD mode.
Hi,
I'm running a Ford -32 Coupe with LS1 from a Camaro 2002 with 243 heads and LS6 cam, Holley single plane manifold and Holley 4 barrel throttle body. I have run 5 iteration, each with a 20 min drive with various loads and a wide band lambda logging AFR error. After every run I have applied the the logged matrix of AFR errors to the VE table with "paste special ...". I also carefully applied interpolation for cells and areas where logged values were missing. After four iterations I ended up with the VE table in the attached tune file. On a fifth test run with logging I still get som bad AFR errors. See the attached log file. There are some few very lean spots and some not so bad but rich spots. If I apply these logged AFR error and try making interpolation the VE table look absolutely crazy in my opinion.
Am I on the wrong track trying to dial in my VE table for SD mode?
