Results 1 to 5 of 5
Thread: 2011 1500 ly6 swap
    Jun 2020
    22
    2011 1500 ly6 swap
    Swapped my truck runs and drives great. Remote start and starting with the key the truck seems to idle low when it starts, how would I adjust the idle for the initial start ?
    2011 1500 Sierra LC9 to LY6 swapped. Motor was rebuild stock. Used a tune from a 2009 6.0 2500hd.
    Thanks Luka
    13,569
    Do you have a log and tune file?
    What parts of the tune did you use from the 2009 file?
    Obviously there are a lot of changes between a 5.3 and 6.0 file, no only just in data but also in the parts they used like injectors and MAP sensor.
    Mar 2011
    Ripley, MS
    1,865
    Quote Originally Posted by LukaD View Post
    Thanks Luka
    You'll increase the startup airflow table. I'd increase it by at least 10-15% to start with.
    Jun 2020
    22
    The only thing I didn?t change was the throttle body parameters. I?ll post the tune here shortly
    Jun 2020
    22
    Here is the swap tune
