Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
Thread: VE Drops to Zero Randomly
  1. #21
    Aug 2010
    Detroit, MI
    932
    Quote Originally Posted by SJ90 View Post
    I never figured out what caused it, but when I returned to MAF/SD combined it went away. I see the odd spike in VE when I log still, but with MAF enabled it doesn't cause any break in power now.
    Did you try the air calc mode patch? This issue is documented fairly well...or the issue it appears to be anyway. You may need to request support to add the patch option for your OS.
  2. #22
    Dec 2021
    22
    That's great that worked out for you, but I'm currently running mixed and still get the odd dip.
    Ah well, it'll work itself out or it won't. It's beyond my abilities to sus out the culprit behind the problem.
    Thanks for the reply!
  3. #23
    Nov 2006
    2,742
    Quote Originally Posted by smokeshow View Post
    I've not had that patch fix it for me.
    I do almost everything in SD. I see it often. adjusting RPM MAP boundaries seems to help but ultimately will still be there.
    2 Bar OS's will also fix it
    Tuner at PCMofnc.com
  4. #24
    Jan 2020
    37
    I have not tried that. What is that/where can I find it?
  5. #25
    7,643
    Not all OSes have it, yours doesn't. When available it's in the Operating System tab/section.
