Hoping someone can help.
Car will idle all day long in some instances, then other times when I'm coming to a stop it starts surging, have had it cut off on me several times, but once I come to a complete stop it'll stop and idle all day long. I can save it by blipping the throttle, but can't understand what mode it's going into to cause this? I'm stumped!
2005 ECM out of a Suburban
2003 LQ4, stock internals
33lbhr flex fuel injectors
LS6 intake with returnless fuel rails, vette regulator/filter
stock truck DBW throttlebody, have brake and clutch switches installed and wired
Elgin E1839P cam (220/224, .575" lift, 112 LSA, PAC 1218 springs)
Large longtube headers
T56
3.73s
AEM wideband on a/c port
Please look over the log and tune, if you see anything that can be improved upon, I'm open to criticism! If you look at the end of the log you can see I can repeatedly get the car to go into this surging mode when coasting down my side road into my driveway.
If any other data or specs are needed, please let me know and thank you in advance!
28-Salty-tune27-reducedpetps_uppedVE.hpt5-1-21-tractorsupplytohome-tune28.hplsalty4.Channels.xml
