Hey guys. So I need help. Ive tuned quite a bit of N/A cars but this is my first time tuning a turbo car. So I'm glad its my own lol but the car is retarding timing above 4k and im not sure why. The higher in RPM and boost I go, the more timing is pulled. Im running like 10 psi at 18 degrees on 93 pump. The car was fine until I installed my boost controller. Fueling was perfect. 0 knock. Nothing and now its scaring me because I have my duty cycle at 10%, basically wastegate, and the car seems pissed. I've been trying to tackle this for a couple days but no luck. I'm attaching two logs and the file. If anyone could help point me in the right direction, I'd greatly appreciate it. Thanks
Also, for fueling I have LU80 injectors with a DW 400 pump and Turbo Kit is the On3 Twin 55mm Top Mount Kit w/ TS Hypergate 45mm wastegates
