WOT delayed or While WOT pcm change to Closed loop
hi guys,,
i have been working from a while with "panther platform" never had any issues
only in this car 2011 Crown vic i can't figure out whats wrong with it
"WOT enrichment"
the car delay sometime going to into open loop (WOT) or while WOT switch to closed loop(0.950 lambda) even TPS shows 76.1% which means
Fully open
No DTC codes and throttle responses very laggy Sometime
i noticed -Accelerator Pedal D when WOT delay happen seems lower percentage than normal -switching to CL at WOT : the Accelerator Pedal D percentage start decease
i tried to lower Pedal POS WOT start about 10% no help
