Results 1 to 5 of 5
Thread: Can't connect to Vehicle
    Advanced Tuner Rockrz's Avatar
    Aug 2008
    I'm right here!
    261
    For whatever reason, my HP Tuners Software will not connect to one of the 2 vehicles I've used to be able to connect to and have connected to before
    On this particular vehicle, I extracted the OE tune before I had a tuner shop tuner the vehicle, and after that was done, I extracted their tune from the vehicle so I would have a back up of both tunes.
    Now, I'm about to sell this vehicle and I'm wanting to write the the OE tune back to the vehicle.
    The first time I was able to connect I remember the program asking if I wanted to use credits for this vehicle so I know the program / interface should remember the vehicle.
    Any ideas on what to do in order to connect would be appreciated...
    Jun 2011
    36
    Does it have an aftermarket door chime for the stereo?
    Aug 2008
    I'm right here!
    261
    Quote Originally Posted by EmmerichLSx View Post
    Actually I did install a different stereo since the last time I had connected that included an adapter so the OE chimes would work... but, the previous stereo had the same and it still worked.
    So you're thinking the adapter that enables the OE chimes to work are interfering with HP Tuners?
    If so, what's the fix for that? Maybe turning off the stereo or disconnecting it's power?
    13,576
    Pull the radio fuse and try again.
    Aug 2008
    I'm right here!
    261
    I'll try that tomorrow, thanks!
    Well, provided the installed didn't put an inline fuse in that's inside the dash.
    I know the fuse block has one marked radio, or stereo, so I'll start there.
