Results 1 to 8 of 8
Thread: maf values?
    Aug 2006
    tipp city
    6
    maf values?
    not sure how to set mass airflow values for a slp 85mm maf. can anyone give me a hand. would this cause the car to almost die at startup? it will surge up and down for about a minute or so then it levels out and runs great. only at startup i have a problem. and it doesn't do it everytime
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,278
    you could swap the stocker back on to see if thats the problem, but yes a different MAF can cause issues if not tuned.
    Aug 2006
    tipp city
    6
    maf
    the stocker is junk wasn't working. i think its the air flow values causing the problem. not sure how to tune for it. was hopeing someone could give me some advice.
    HP Tuners Support
    (foff667)
    28,278
    find the values for an 85mm maf and adjust your maf table for that.
    Nov 2002
    Central Florida
    2,503
    SLP hoaxed the electronics so it produces a "similar"
    output to a stock Oreo MAF. Whatever you may think
    of SLP's definition of "close enough".
    Remove the resistor they soldered in there and use the
    truck table from a 6.0, one that has clean low-end
    appearance (some are discontinuous or drop out early
    etc.).
    This is the resistor:
    Attached is my collection of MAF cal curves (green = good):
    Aug 2006
    tipp city
    6
    ok thanks for the help guys.
    Oct 2005
    TwinCities, MN
    37
    jimmyblue: what exactly does the green=good refrence mean for your MAF cal curves?? Are these the ones that you have calibrated?
    Nov 2002
    Central Florida
    2,503
    These are all stock GM cal curves but some stop short
    on the high and/or low ends, or have discontinuous
    data in them. The Holden MAF is what should be on
    every F-body and the truck MAF one is the fattest of
    the 85mm cals but happens to have been dead-nuts
    on my car, commanded vs actual AFR at WOT and
    decently low negative trims elsewhere.
    If you found the one too fat you could try out the 5.3
    which also appears well-formed, just lighter.
