Originally Posted by
cwmusser
I'm new to this forum but see it as a place where most members are into tuning. I'm running a 418 cu in LS3 with a 4150 style Holley intake and throttle body with Holley 42 lb injectors, all running off the earlier 24x ECU system. My AFR is set to run at 14.68 on closed loop. My question is; I can't seem to get my engine to run any cooler than 230 degrees. I have a big cross-flow radiator (17.5" x 31.5"), 180 thermostst, Edelbrock hi-flow pump, and twin Maradyne (12" & 14") fans. My plugs look like it's running too lean and the engine acts like it's too lean but my tuner says that can't be because it's set at the stoich (14.68). I talked to Holley thinking that since my intake system is completely different than the factory style, maybe I need to be at a lower AFR. They recommended I try 14.2 but I would like to find out from real world users what seems to work. Can anyone advise??? Thank you!
