Originally Posted by
murfie
Throttle angle equals an effective area. pressure difference across an effective area is equal to airflow. With a know entry pressure, a throttle angle will be a mass airflow. Throttle body model as simple as it can be explained.
Calculated MAP + ETC vaccum = Entry pressure. Entry pressure should be assumed as barometric pressure.
Yours doesn't add up. MAF values are driving the calculated MAP too low. Manipulate your low mass airflow values of your transfer, along with your low injector slope, as to not disturb your lambda ratio, but bring your calculated MAP value up.
Keep them both in inHg or PSI, its not rational to look at them in different units. looking for 14.7 PSI or 29.92inHg, unless you are at higher elevations.
Two pressure sensors and an accurate MAF transfer (not just one that fixed fuel trims), are needed to derive an accurate throttle body model. Outside of that you will play with it on every car you use it on, with no confidence in its accuracy.
