Results 1 to 6 of 6
Thread: Manifold Volume / Supercharger Displacement
    Jan 2017
    Tucson, Arizona
    16
    I have not seen this discussed at all and it is a thought I had when I replaced a 2.3L blower with a 4.2L. Should the manifold volume be increased?
    Tuning Addict
    6,802
    Yes, as long as you want transients to be more in line... Anytime you add FI manifold volume should be increased - at least in my opinion
    ~Greg Huggins~
    Dec 2017
    14
    It seems to me that function acts as an "accelerator pump" The lower the number is more is added at tip in
    Jan 2017
    34
    Quote Originally Posted by Mfdcar51 View Post
    I saw the same thing... which one is correct?
    Advanced Tuner bbrooks98's Avatar
    Oct 2011
    Gainesville, VA
    301
    Quote Originally Posted by colo_evo View Post
    That function does seem to act as a Accel pump when moved around although i don't think that's what it is for directly. Accel fueling is more a side effect of it's purpose to determine air speed/volume of the manifold from what i understand. I've also noticed it can cause some strange over fueling on decel if too far outta wack. Does the blower actually displace more air space between the Throttle body and head? My OPINION would be maybe up it slightly, but from one blower to the other not much is needed.
    Senior Tuner CCS86's Avatar
    Austin
    1,089
    I have done a bit of testing, and saw effects on transient fueling. But I definitely wouldn't call it an "accelerator pump". 'Accel Transient Fuel Gain' is the table that acts as an accelerator pump.
    I found it hard to separate the effects of manifold volume and transient gain. I think it functions more as a transient delay that affects how STFTs work. I think it stacks something on top of the O2 transport delay during times of rapid throttle movement, to keep the trims well timed and prevent a chase condition.
