Results 1 to 7 of 7
Thread: Beta software crashed during loading
    Jul 2016
    Richmond, TX.
    83
    Out of the blue, my HP tuners software crashed during a tune load. I'm sitting in a parking lot and cant get the car to load a tune or run, software crashes every time I try and load. Tried different computer and it still crashes software. Tried different tunes and basic software and still crashes software. Is my ECU toast? Is there a way to reset ECU?
    Dec 2017
    767
    Did you update your .net framework they told me in a email do not the beta will crash .
    Oct 2016
    Poland
    1,744
    Try to disconnect negative terminal for 20min.
    Apr 2018
    605
    I've been using beta and have done numerous calibrations without issue (thankfully). Were you doing a write cal or write entire? I'm using an old laptop but it has an up to date Windows 10...
    I had this happen to me once on a 2005 F150 when I was writing cal only. Crashed and PCM was dead. Luckily I had the original PCM read that I had read with 3.6 (not beta). I was able to open my old read file in the non beta version of the software and write entire, and it recovered.
    28,268
    I recommend contacting support https://support.hptuners.com/index.php?/Tickets/Submit with issues such as beta software crashing.
    Jul 2016
    Richmond, TX.
    83
    Actually, found out the pro programmer I bought was the problem. My buddy was able to swing by with his programmer and it worked fine, so I guess I need to send it back to HP Tuners to see why it failed. Only had it a few months with a couple of uses behind it.
