So I upgraded my LS6 with a TSP 233/239 cam, ported the stock heads, full exhaust and was intending on changing out my injectors to LS3 injectors but I am wondering if this is really needed since i'm shooting for around 420 RWHP? From what I have read the LS1 injectors can handle up to 450 RWHP. I understand this pushes the injectors closer to 100% duty cycle but I see mixed reviews for that on good, bad, and doesnt matter.
Second question - If i do go through with the injector change, I was going to use DSteck's injector data for LS7's since the LS7 and LS3 injectors are the same. Is there anything else that needs to happen other then dialing in the VE after the change? I see offset vs voltage, flowrate, and short pulse adder but is this all that is really needed? Could really use some guidance or maybe some input from someone who has done this change if I end up going through with it.
THanks
