2007 Escalade, slightly tuned (go easy on me, it's my first time) running 87 pump gas and zero mods to the engine aside from removing the cats. On the VCM scanner I am seeing a lot of part throttle knock retard and am looking for advice. I followed the instructions on the tuningschool video about fixing knock but it seemed to get worse after doing that. Also zeroed out the burst knock table (12765) I can hear what sounds like a wrench tapping on the exhaust manifold when it is showing knock. Is it just knocking and I should run better gas? I did change the driver side engine mount too. What confuses me is that it only does it part throttle and very little at WOT. Also there was almost no KR until it got up to operating temps. Here are my scans and tunes for you to pick apart:
Tune2+catdelete is before messing with the spark tables following the tuningschool video
Tune2+catdelete+KR is after messing with the tables
Drive2nocats is a log from after removing the cats
KR1 is a log after messing with the tables.
KR2 is another drive right after KR1
Tune 2+Cat delete.hpt
Tune 2+Cat+KR mod.hpt
Drive2nocats.hpl
kr1.hpl
kr2.hpl
