I am attaching a log file & tune in hopes that someone here can help me. I have transplanted a 5.3 into an 87 K10 truck. the truck has a small cam that i will adjust for as soon as I can get it to run and it is using the original 700R4. The fuel pump has been replaced and is holding around 54-56 lbs. There is no vacuum leaks that I can find. The truck fires right up and will idle fine, but it wants to die if it accelerates past about 1000 rpm's. Thanks for any assistance.James 041818.hptIdle but dies on acceleration.hpl
