With the 6speeds it depends on the year models - I've done it both ways, but on the earlier ones even if you disable TM, your not actually disabling it 100% - in fact only about 70% or 80%... 14 and newer ones pretty much completely kills TM and goes into a default trans pressure setting setup - which I've even with certain customers dialed in for regular driving after killing TM per request (very time consuming this way, but can be made to work either way you choose)
What your looking for on the torque is something around 900 to 1000 ftlbs around 4500 to 5000 rpms... You might actually want to open the torque editor and modify the model by hand - just use the spark setting near what your wot timing is... Make sure to scale your airmass setting up to a max 2000 setting (this is an actual airmass of 200 on your spark tables)
