IMG_8705.jpg I am very new to this I have a 03-04 lq4 6.0 twin 70mm turbo sheet metal intake with ls2 5 pin maf 2 bar map it is running extremely rich won't stay running the wind band stays around 10.8-11.3 sometimes jumps to 12.5
Please help Thanks Robert
These injectors Siemens 60lb/hr Fuel Injectors Fit EV6 USCAR Bosch Mototron V8 Flow Rate in CC per minute: 630 CC/min @ 39.5 PSI
Flow Rate in LB per hour: 60 LBS/HR @ 39.5 PSI
Flow Rate in CC per minute: 660 CC/min @ 43.5 PSI
Flow Rate in LB per hour: 63 LBS/HR @ 43.5 PSI
Resistance: 12 ohms
Voltage: 8-15 Volts, nominal 13.5 Volts
Amperage: 1.0 Amps
Pressure: Min 30 PSIG / Max 100 PSIG
Spacers/O-rings Included: YES, on the injectors
Fuel Delivery: Multi-hole disc
Electrical connector type: EV6 Oval Plug
Overall Length: 3 inches, 74 mm
Diameter: 16 mm
Orings: Top and bottom, 14.
base tune test.hptstart first.hpl
