hey everyone new tuner here, recently fell into a boosted Camaro Z28 M6 , and kind of fell in love with it, so decided to dive back into this car stuff, so a little about the car....98 ls1 with stock ecm, 317 heads, btr .660 springs, ticks turbo cam, bbk intake, 76mm on 3 kit, currently running 5lbs, stock bottom end , deka 60 injectors, racetronix kit and a wal 255 pump holds steady at 62psi, might be missing a few items but that's most of it... oh yeah its running an SD tune
so anyways looking for any and all tuning help and suggestions , ive done quite a bit of reading before and after purchasing my hptuners pro, but would love to hear anyones input on how to make things easier or what to look for in my tune, Ive only logged some LTFT and made small adjustments after seeing that the map was around 8-10 percent lean in the cruising areas, i've smoothed the VE and spark maps , I also pulled 4 Degrees of timing from most of the map until VE was adjusted.
overall the car runs well, the only issues being small spikes of knock mostly at 2,800 rpm which I'm pretty sure is some kind of harmonics , the exhaust dumps from the turbo next to the transmission on passenger side and you can def hear that's where the engine exhaust starts changing notes, and knock under WOT shifts, mostly 3rd to 4th gear.
aside from the knock, the only other issues this far is when the car is in warm up mode after a cold start (90 degrees ambient) the best I can describe it would be when the car is switching over from cold start to operating temp, it will fall on its face from what the wideband says is a lean condition during a shift, and will spudder for a sec before coming back
Again thank you in advance for any advice
