You should read everything you can find on this site concerning tuning.
Just use the search box,there is alot of great info here to help.
There are also some good guides available on the web.
I have read and watched so much in the last 2 weeks, I think I have gotten to the point where I am saturated and starting to get things mixed up
I see that the VE is populated,it looks a little rich.
The PE Power Enable EQ Ratio is set to 1.
Do not use WOT until this is changed. It needs to be set to around 1.17, which would give you a A/F of 12.5.
Currently it has no power enrichment. Current tune 14.68 (stoich) /1 (PE EQ)= 14.68.
Should be around 14.68/1.17=12.54.
I thought I had changed that to 1.2. I already shut the laptop down for the night but will check it first thing tonight when I get back to work. Thank you
I would also raise the PE Enable MAP to 75-85 kpa from the current 55 kpa.
Closed Loop Enable, ECT vs IAT, is set to max 285. Will this not keep it from entering closed loop?
Yes, change it to 130*.
Enable LTFT
The MAF has the IAT sensor in it.When disconnected, it reads like -40* and goes rich among other things.
Noted
I am not given the option to change the Mass Air Flow Freq High, the box is not there for me to do it.
It is in Engine Diag>Airflow>MAF>MAF Frequency Fail High.
This option does not show up for me, in the diagnostic section it only has a list of the DTC with the drop menu to change between first/second key on and the SES light check box, there are no other tabs or menu's
You also need to log these channels:
O2 sensors (B1,B2,sensor 1),Inj pulse width (B1,B2),Inj duty %,Knock Retard
There are other things that I may have missed,but this should get you started.
The experts on here will gladly help you.
