Hey guys I am new to the hp software and cant figure out why the ecu pulls timing down between 0 and 3 degree if i give it any throttle (10% or more) and of course it feels as if it is going to stall and doesn't want to go anywhere, even commanding 2nd gear I couldnt get it to rev past 3500 easy revving with light throttle. Scanner is showing no knock.
I locked the absolute timing in scanner to 24 just for testing and it actually runs night and day different of course and it will rev to limiter at 5300. I dont want to make to many changes to my VE and cruise/part throttle until I can find where the timing is going.
Can someone look at my tune and see which table I am overlooking that is pulling all the timing out?
Ive made low and high timing tables the same
set burst knock, AFR, ECT, IAT, cat and egr tables to 0
and changed torque reduction to 0 in the trans tab
My setup is
72 C10 with a bone stock 5.3 (longtubes), 4l60 trans with stock converter.
16:46:48, 16:47:30 are 2 places you can look at on the 1stdriving1
at 17:33:06 you can see where I locked timing and it actually runs right
2002ECUHeeter72C105.3Basehpforum1.hpt1stdriving1.hpl1stdriving2.hpl
